Quote:
Originally Posted by Gsxy99
so then you guys would suggest running h20/alcohol.... Not 100% alcohol?
The alcohol helps us that are stock with 91-92 octane instead of 93+ as well as running on stock injectors. The alcohol adds octane and fuel so you don't run lean under higher boost. The water for the cooling effect.
