View Single Post
Old 07-30-2005, 06:56 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #16 (permalink)
99GSX Swede Offline
Proven Member
Tech Posts: 55
Classifieds Rating: 0
Reputation: 99GSX Swede is an unknown
Quote:
Originally Posted by spyderturbo007
Do you run a dual stage kit or a single stage? I am going to be purchasing a kit within the next 2 weeks to help with the stock SMIC. I'm not sure exactly which way I am going. I wasn't sure if one nozzle before the SMIC in the LICP would work, or if I should go with one after the SMIC in the UICP . Either that or a dual setup.
I have heard that putting one before the SMIC is worthless because you are wasting the cooling effects of the SMIC and should inject directly after the SMIC. But, I think I'm weird trying to run the stock SMIC.
I run the single stage. But then again I am setup with a 3" MAF in a blow through setup. You don't want the injection to run through your MAF. So I am just running a 300cc nozzle right into my TB elbow (about 4"-5" away from the actual TB).
If you are on stock MAF then you can run the dual stage through you SMIC as long as you are not running straight Meth. (it will eat away at your SMIC).
