95talontsi
- 274
- Jun 29, 2002
Princeton,
would a 190 pump be good enough for a big t28 and a small 30-50 shot of nitrous. I heard that the 190 is good for 390 hp, is this right.
Originally posted by NJGSX96
The 190 would be good enough. I would suggest, however, the Supra pump. Couple bucks more for a much better fuel pump.
Originally posted by larryd
would you say the same about the L2R + 30-50 Kevin.![]()
uhm no, its actually running worse
Originally posted by Z1500
You want +30-50hp? L1R. You don't need to keep filling it at $30 a pop.
WTF is wrong with your car Larry? What did you do to make it run worse?
Hell, just saying you have Nos is worth it's weight in gold and means you got a fast car, right?
Kevin
www.agpturbo.com
a supra pump that is rewired flows 290 lph @ 43psi fuel pressure. the Walbro is 255 and the supra pump is quiet like stock, the walbro is also known as whinebro![]()
