help installed 550 inj and now idles at 3000 rpm
bindiman99
Apr 12, 2005
beaverton, Oregon
i installed rc 550 injectors and a venom fuel rail today and now my car idles between 2700rpm and 3000rpm and when in drive its about 1400rpm what can i do to fix this and what did i do wrong please help
how about listing ur mods first. then how about buying an SAFC and learning to tune since i have a feeling you dont have one...
for the mods here it goes
injen intake
14b turbo
greddy 24v front mount
rc 550 injectors
venom fuel rail
b&m fuel pressure gauge
3" cat back exhaust with test pipe and apex n1 muffler
greddy e-01 boost controller
safc II
hks turbo timer
ipt shift kit
hks ssqv blow off valve recirculated
magnacore 8.5 wires
ngk plugs bpr7es .28 gap
greddy oil catch can
hope this will better explain my situation
and get me some help
thanx
Dont take offense at this, but did you remember to replace the injector seals? Also, did you tune your Safc to compensate? Usually w/ 550's start at -18% go from there. Its easy to look over simple mistakes! :dsm:
I second what Hitchhikkr had to say about the inj seals......if the rail and injectors is all you touched, you probably have a vacuum leak at 1 or more injectors. Just my 2 cents, I could be wrong.
