Louis53123
- May 8, 2005
Tenafly,
New Jersey
Whats good everyone, i finally got my car back from getting it built, i have the following....
I have a g1, 6 and 4 bolt. My current mods are:
Block: Weisco Coated pistons, Crower Rods, Balance Shaft removed, and new seals, gaskets ..
Head Has Web Street Grind Cams
Fuel-Full fuel system
Intake-2g mass air, FMIC, Magnus intake manifold and for my tuner AFC
i got all the other supporting mods, exhaust, clutch etc
I currently have a t3t4 turbo with a 57 trim. Its tuned to about 15lbs of boost. How much boost can I run to make this a daily driver, is 20-22lbs to much on pump gas?
Any comments would help!
but it's all up the the ECU. At 22lbs you might be fine, with a good timing curve and no knock. But another 2 lbs and you might end up knocking and having the ECU banjack your timing. You just need to get a logger involved and see what the timing curve / knock looks like.
