GS_EX_99
- 30
- May 4, 2005
Lisle ,
Illinois
I have basically stock 99 gsx, MBC intercooler piping and bov. I know that im hitting fuel cut at around 16-17psi. So i try to run on the edge of fuel cut. If i get an S-AFC II and a 255lph pump, with 680cc injectors.
A.)Can i turn up the boost past 17psi w/ the T-too small, without hitting fuel cut?
B.)Can i remove the MAS, or will it need to be replaced with a GM MAF and Translator?
C.)If in fact i will still hit fuel cut, will the HKS fuel cut defender work with a 2g?
Thank You.
Thank You.
