Drewcool2
- 234
- Jun 15, 2003
Downingtown,
Pennsylvania
My car has been sitting for 4 1/2 weeks now due to some clutch work. I finally started it up today and right away I heard about 10x the valvetrain noise, it ran extremely rough, and I had to struggle to keep it running. I thought it would get better with some time, but it never did. I have fresh 20-50 mobile 1, my oil pressure was fine, and my 272's were visibly getting plenty of oil up top. I did a compression check and cylinders 1 and 2 (driver side) had ZERO to 1PSI
, while cylinders 3 and 4 had 165-170PSI. Adding oil to the dead cylinders only added like 2PSI.
What would likely cause this to happen? My motor ran great 4 1/2 weeks ago.
, while cylinders 3 and 4 had 165-170PSI. Adding oil to the dead cylinders only added like 2PSI.What would likely cause this to happen? My motor ran great 4 1/2 weeks ago.
Thinking about having my mechanic do it in his spare time, or some dsm shop. And what should I do while i'm in there besides new hg, head studs, and intake manifold gasket? Should I do the timing belt, tensioner, and water pump? I don't plan on keeping this car much longer, and the belt was just replaced 4k miles ago.
