jayboogie
- 61
- 1
- Apr 25, 2005
Elk Grove/Sacramento,
California
i have a 1990 basically stock talon tsi fwd ive owned for a month.
i bought and made a boost leak tester... the PVC cap for .74 cents, rubber fitting with the two bands for $3.76 (or somethingrather) from the Elk Grove Home Depot and rubber valve stem i got for free from Elk Grove Honda Motorcycles/Hobby Vehicles. grand total: $5.08 with CA taxes. i drilled the hole at the tip and bored it out to fit the valve stem... made all bands tight and hooked it up to a 150 psi air compressor...
the leak thats causing all my problems... is my #2 fuel injector (counting from passenger to drivers side). the port where the injector goes into the block is leaking and i can't figure out why... after looking at several other fuel injectors... my best guess is that this is because it's not "screwed in" enough. i didnt see any gasket on any of my injects so this is my best guess. what else could be the problem? im guessing that since it traced it all the way to my injector... there's no other leaks in the system?
will fixing the seals make my gas mileage go back to normal?
thanks all!
thanks all!
... k sweet... annndddd this will fix my gas mileage problem? ill do a boost leak test afterwards just to see if im good.
