jooc
- 1
- Aug 16, 2008
warren,
Ohio
hello to everyone, not really a newbie but to the site i am.. i have done alot of looking around.. but here is what im looking for..
i have a 97 talon.. 97 ecu.. 95 engine harness..
the 95 engine harness for mpi/mfi relay is one plug comes with the same amount of wires and each wire color is different and has its own meaning now the harness does not have a plug on it just the wires.. i have the original 97 relays with the plugs on them and wires off them.. i dont need to know from the ecu pin out.. but from the plugs off the mpi/mfi relay themselves.. what each color wires represents and go to what wire so i can wire the harness together.. 8 wires
95 harness has 8 wires all different colors besides 2 red/black wires
97 harness has 8 wires all different colors besides 2 red/black wires the same
2 black/white wires the same
i believe the red/black wires are a fuse link so they go together
the 95 has a black/blue - black/red - black white
the 97 has 1 black/blue - 2 black/white
others wires are color coded to match each other.. just want to double check that i can wire those wires that color match to each other to each other
also im about to wire some slim fans up.. i read the thread on how to do this.. my question to it since i cant reply to it is..
there are 4 wires that come off each plug, 2 off the slim fans..
positives get tied to positives,
negs get tied to neds,
the oem are 3 step fans
and once the relay kicks on regardless the slim fans will kick on
now the a/c fan.. will this ever kick on since i deleted a/c
can i wire the fans off of the rad fan wiring and not use the a/c wiring so that my the rad fan will turn on both fans and i dont have to turn on the a/c at all for teh a/c fan to kick on? did this make sense?
