Please Support JNZ Tuning
Tri-metal vs aluminum rod bearings
lars y
141
Oct 11, 2007
Halden, Europe
I read up on the difference regarding the main bearings, but i couldn`t find much information about the rod bearings. Will the same principles apply on the rod bearings?
From what i could gather the tri-metal bearings can withstand more pressure but the aluminum bearings are more forgiving.
So in a high HP engine the tri-metal would be the better choice, while aluminum is cheaper and better suited for a stock engine.
Thanks
The aluminum bearings are way more forgiving to the crack shaft as they are a very soft metal. I use the aluminum bearings and have no problem with them. Alot of engine builders perfer the aluminum bearings as well. They are cheaper but dont let that fool you.
Tri metal bearings are mostly used for high reving engines and can take a lot of abuse when they are set up properly and the correct series is chosen.
