Reputable Machine Shop?
Davids97Eclipse
54
Apr 4, 2011
Aurora, Colorado
Hey guys just removed my head and it looks like the block and head need to be resurfaced anyone have a Reputable Machine Shop they'd reccomend? Thanks, dave
I have had very good luck with Havana Machine Shop. have never gotten a head personally serviced there but they do all the work for my dealership and have done a block and crack for me. They do good work. Never hurts to call.
You can't just resurface a head. When a head warps, it will affect the valve-to-seat alignment and all of your valves will get leaky. You need to have the head rebuilt proper. We charge $450 for a head rebuild if you bring it in. That includes:
Resurface for any type of gasket (MLS or OEM composite)
3 angle grind
Proper grind for turbo applications so you won't end up with leaky valves in the near future
High temp valve seals which will never smoke
New guides
Replace valves, rockers, keepers, retainers, and springs as needed
Complete cleaning properly without sandblasting
New cam seals
All tricky areas are sealed proper so you won't have oil leaks
The block also needs to be torn down, cleaned and bare bones for a proper resurface. We charge $100 for deck resurfacing for any gasket type. Unfortunately, 4G63 blocks tend to sink at the fire-ring area, so it's very important to resurface it while everything is apart too so as to prevent pushing coolant.
Our heads seal and live in high powered applications and we rebuild several engines a week.
We are located:
Jacks Transmissions
3920 North Weber St.
Colorado Springs, CO. 80907
719-243-5305
More info about our engines here:
Jacks Transmissions LLC — Engines (4G63, 4G64, 4B11)
We are also a supporting vendor :)
Thanks!
Jack
heads by drew did an awesome job on my head and have a couple buddies that have went through him for there dsm heads 6bolt and 7bolt and he only charges 350$ the turn around time on my head was about 3days hahaha :hellyeah: and this includes hot tanking the head tear down, new oem valves, valve springs and retainers along with valve stem seals, and the deck of the head is just tits!!! :D
or jacks!!!!!:hellyeah: they also do awesome work ive seen a couple of cars with there trans/motor work that are still running and have been put through the paces haha like really have been beaten on and still are running amazing!! :thumb:
