915dsm
- 202
- Nov 9, 2010
El Paso,
Texas
Hi,
i need help figuring out why my cat idleas at less than 500 rpms on the cluster but in dsm link its indicates double that. my wideband says im running lean as well at idle. the car has all new internals. the swap consists of complete 1g long block swap.
1g head with Delta 272/272 cams
evo 9 springs and retainers
1g head crand and rods
2g pistons and compression
1g cas with harness for cam and crans sensors signal
stock injectors
small 16g
fp exhaust mani
cyclone intake mani
CAS timed at 5 degrees (link says its at 13)
Could it be an ecu problem? do i need to check for any leaks? im correcting some exhaust leaks from the o2 housing to the downpipe.
anyones help would be very apreciated.
stock injectors
small 16g
fp exhaust mani
cyclone intake mani
