awdspyder98
- 121
- Dec 31, 2011
houston,
Texas
Just wondering if people are tack welding the flexplate to converter bolts on the kiggly flexplate? Just wondering if the problem persists on the bolts loosing after the install?
)I've never heard of that on any application tbh. QUOTE]
Im suprised.. Most autos that are over 350-400whp usually has to tack weld the bolts so they dont come loose.. esp if your balance shafts are deleted. Tack welding + stock flex plate has held up for a few years for me, maybe Im one of the lucky ones.. but as soon as I hit over 450+whp.. thats when the flex plate broke.
Why don't more people use safety wire? It's so cool and works so well.
As a Machinist and Weldor (different than a "welder")
Regarding safety wire, one would attach them all together correct?
Yup, safety wire is definitely the way to go. You'll spend a little money doing it, but doing something right almost always costs more. Gotta pay to play. And it's never a bad thing for a 'car guy' to be adding to his tool collection.
wire and pliers - $30
drilling fixture - $40
carbide drill bit - $10
So, for $80, you now have the ability to drill and safety any bolt on your vehicle. Do a few for your friends and make your money back instantly.
would the wire prevent them from turning in the slightest?
Yeah, it puts tension on the bolt to pull it towards being torqued down
The bolts attach to one another in a staggered fashion, each bolt effectively tightening the other. Assuming the wire tension was properly set this seems like an effective solution.I just got up close to a big military gun and there is safety wire on everything. If it's going to keep the bolts on that tight, it will keep your converter tight.
I assume the 2G bolts are 1.25 pitch? 12mm x 1.25 x 16mm long?
ARP offers a set for Porsche that are damn close. The thread is right but they're 19.5mm long.
Thanks for the links, Eric. I had no idea ARP offers flexplate bolts for the 4G. Oddly enough, I don't even see them listed in their catalog but those part numbers do come up in my system at work. Time to get a set on order.
