rr06rs
Supporting Member
- 421
- 2
- Apr 25, 2009
Jacksonville,
Florida
I'm wondering if a +20 offset on a 18x10" rim will be too aggressive for the wheel bearings on a daily driver under hard cornering. Please refrain from the, "why would you....." this or that comments. I'm aware the wheels won't tuck stock fenders...I'm aware 17's are more suited for handling, etc..... I just want to know much the wheel bearings can take when the car is daily driven and not constantly being pushed to the limits in EVERY corner. I assume in a track only application, this offset would really take its toll on the bearings but not sure about a daily driven setup? Also, I've always heard that 27 offset is the perfect offset for a dem but I don't know if that's only for a 1g or if it applies to a 2g as well? If it does, I would assume that +20 would be not much different than running a +35, as its still 7mm from +27 but just 7mm lower rather than higher? TIA for any insight anyone can provide.
