2g2ner86
- 62
- Apr 17, 2010
Hazleton,
Pennsylvania
Ok. I have a 98 gst and I just completed a full 6bolt 2.4 with 1g head swap. The motor came out of a running car so I know it is good. I hooked up everything and when I try to start the car, i hear my fuel pump whine and my starter just spin. It's like the starter isn't contacting the flywheel. I had the starter grounded to the transmission so I put the ground on the other prong on the starter itself ( the post closer to the block). When I tried to start it again it just clicked once like te starter was bad or no battery power. The battery reads 12.3v. Could anyone help? And my flywheel has all of its teeth and I used the plate from my prior motor for the tranny and starter.
