93 Eagle Talon TSi
- 127
- Jul 29, 2012
Toledo,
Ohio
im thinking about buying a 16g for my 1g and wanting to know if its a direct bolt on or need adapters or different parts.
Direct bolt on.
thank you. do i need to change my fuel pump or fuel injectors
well mine has a 14b stock and it snapped a shaft and got an offer for a 16g and wanted what all is need to do or need to make it run right so i have to tune it if i put the 16g on
Yeah, that 20g is a bit above your needs. That's a good 400hp+ turbo. I would still suggest finding a 16g over a 14b. It will bolt right up and you don't have to do anything to run at stock boost. No tune, no injectors, nothing until you want to crank up the boost. Then when you want to crank up the boost, you have a good 350-400hp turbo depending on which version you get.
And in my experience, a good condition 14b isn't much cheaper than a small 16g (typically on Craigslist). Pay the small difference now and you'll be glad you did down the road.
ok thanks guys
i also talked to jusmx and he said it doesnt look like it has a wastegate and i will have to custom fab it so dont think im getting it
20g on a bone stock car will be a turd.
