nitrokid
- 78
- Jan 23, 2009
lincolnton,
North Carolina
Ok so I building a 420a for the eclipse keep in mined this is going to be my weekend car not my dd. I am trying to decide if I should go 10:5.1 or 12:1 I will still be running pump gas. I can't run e85 cause it is not being sold around here I wish I had that option but once again I don't. the other parts I am going to be running are below this will be my set up.
crower3 cams
indy valves
afx ecu
and full msd ignition
Also the car is going to be staying non turbo so I don't want to here how I'm wasting my time not going turbo.
crower3 cams
indy valves
afx ecu
), that may or may not be a sticky wicket. I still believe that 12 to 1 can be done on pump, but until I actually do it, I won't say for sure. Keep in mind that if you do try to go 12 to 1 and it doesn't work out, you will be forced to either change out the engine or go MS (where you can adjust out any problems).
