rr06rs
Supporting Member
- 421
- 2
- Apr 25, 2009
Jacksonville,
Florida
I'm trying to decide which to go with and was wondering if anyone has had experience with either yet? I know its a HUGE gap between the two (61.4mm vs 67mm) but I'm worried that if I go with the s300, it might not be much of an upgrade from where I am. I currently have an h1c/6blade super hx40 hybrid in a custom machined FP bolt on housing. On the flipside, I'm also worried that the 67mm will be too laggy and unresponsive. Here's the thing though...along with the switch, I'll also be going from an FP manifold, to a true twinscroll tubular manifold and divided exhaust housing. In addition, I'm also going from a stock 6 bolt block to a 2.3ltr stroker with Oliver rods and AMS spec Ross pistons that are 9:1. So the twinscroll, higher compression, and added displacement almost completely offsets the added lag from the 67mm. Looking for input and experience....?
