blasterracer817
- 71
- 3
- Jun 29, 2012
Winona,
Minnesota
My question about Dsm link is. Is it possible to have dsm link switch on a secondary fuel pump and set of injectors when the motor hits boost?
example:
Lets say im running 750 injectors with a walbro 255lph in the stock tank running 89 octain for just cruising the streets, however if I went to a race or canyon run etc and got into boost could it Link be programmed to switch on a secondary set of injectors like 2000s and a second walbro 255lph in an eight gallon fuel cell than is filled with 116 cl so you could get a 100-105 octain mixture when in boost?
The second reason to this would be fuel economy while daily driving, If I was running a set of 2200 injectors I think I would be spraying a little more gas than needed for a 65mph cruise down the highway with no boost.
Any input appreciated,
thanks
example:
thanks
... an E16g or 20g, a good set of 1250-1350 injectors, rewired 255hp pump, AFPR, ECMLink, and (optimally) E85 fuel will give you about everything you need for a very fun (ie quick), reliable, and fuel efficient DD.
