tbag1122
- Jun 13, 2012
Wis Rapids,
Wisconsin
Hello all, I am new to dsm's and turbo cars. I just recently purchased a 99 gsx with 72000 miles on it. Just wanted this car because I thought it was a great looking car. Plus I wanted better gas milage than my jeep was giving me and awd was a big plus. I am using this as my daily driver and have no intentions on modifying it. Before I bought it I test drove it twice and all seemed good. I even got a mechanic to look it over and he said everything looked ok. I am still happy with my purchase but I do have some concerns. I've been wanting to ask this for a couple weeks now but I've been doing a lot of research so i don't ask a question that has been answered before. Now I know some of these concerns have been addressed but my main question will be is one of these problems causing all the other ones.
So when i picked my car up I drove 30 miles to go home and as soon as I enter my town the check engine light came on. Also my dad followed me home and he said he saw blue smoke coming out of my exhaust. Now occasionally when I'm downshifting to slow down and stop at a stoplight I'll see a huge cloud of smoke. But not all the time. From what i read it could be turbo seal, valve stem seals, piston rings, and pcv valve. Well i replaced the pcv valve and for some reason it seemed to have gotten better but I'm not certain on that. So I popped of the intake side of the turbo(the hose leading to the air filter) and there wasn't any oil in there. I also reached my fingers into turbo and didnt really feel any play in any direction. I took off hose going into throttle body and again no oil in there. So then I took off inlet side of the intercooler and that was pretty moist with oil. But from what I've read, it is normal for some oil to be in there. It wasn't dripping out of there either. So does this rule out the turbo? Now when i first start the car absolutely no smoke comes out. So i would think that would rule out the valve stem seals as well, leaving me with a possible piston ring problem. I plan to buy a compression tester very soon so i can test that theory.
Now for the codes. I have 3 of them. P0505, idle air control fault. P0446, evap fault. P0420, catalyst efficiency fault. Now my main question would the oil burning be causing any of these faults? My idle is a little funky which is why the p0505 code is probably being thrown. But could the burning oil be messing that up some how. I have ran a bottle of injector cleaner but that didnt help.
Now for the hesitation. Usually occurs in 2nd and 3rd gears between 1700 and 2800 rpm's. Don't feel it in any other gears so that part is weird to me. But is this the oil burning dirtying something up making it act this way. Now the previous owner said he changed plugs and wires pretty recently. But it could've been b.s. so i will change those as soon as possible to rule that out. I did check the gap and it was at. 028. The plugs didnt look horrible but I'm not much of a mechanic. I guess it could also be fuel filter but still curious if the burning oil ain't doing some thing goofy here.
Ok it's getting late and I think I've dragged this out long enough. I will add that I'm not a total noob when it comes to mechanics but I'm not great at it by any means. Used to be a mechanic in the army but never did the trouble shooting just replaced parts when told to. Also my tools are extremely limited. Also like i said this is my daily driver so if I don't feel confident in doing something i will take it to a mechanic. Just want to get some advice so i don't get murdered in labor costs of trouble shooting the problem.
Thanks for any advice in advance.
Travis
Travis
