Custom GSX
- 83
- May 13, 2012
Denver,
Colorado
I have been searching for awhile and maybe not yet stumbled upon it, but I'm looking to find out if and can tell a 4 bolt from a 3 bolt rear diff by just looking. I have my 90 GSX on jacks the other day and seen it read BF? Viscous LSD on the diff cover. Now I have not found out if LSD is a 4 bolt or could be either???? If anyone can throw some advise that would be great.
From stock state, only 1990-1991 1GA DSMs had 3 Bolt rear diffs, 1992-1994 1GBs got the 4 Bolts. Most were LSDs, nut not all. You can also inspect your driver's door sill for an OEM ticker in orange color that says: This vehicle is equipped with a limited slip rear differential. I've searched a lot like you for knowing all that
