Cant fit a wrench in here... help
Funfettie
419
2
Sep 19, 2011
Menomonie, Wisconsin
Hi there,
So im trying to tighten a -6an coolant line on my EF4 turbo, and I cant fit any wrenches between the comp and turbine housing on the turbo. Anyone run into this issue before, and anyone know a way to sneak in there with another tool or device?
Thanks
Tanner
I just took my grinder and narrowed down my wrench really thin. took one min and now i have a wrench just for pulling out turbos. and i didnt have to pull my compressor housing.
compressor housing needs to be removed prior to installation . impossible to do on the car. of you remove the housing basically comes down to un fastening the v clamp and wasetage rod. should pull right off. theres a pin that has to meet the hole on compressur housing when you reinstall or will be out of balance.
