bcjjones
- 509
- 6
- Nov 3, 2011
Austin,
Texas
On my stock 1g 6 bolt im able to run all the way up to 22-23 degrees of timing at 10.5-11.5 afrs at wot creeping to 23 psi and falling to about 18 psi by redline.
Basically on the two higher (11 and 12) load rows at 3k rpm im at 15 and 14 respectively. Then it increases by 1 degree for each rpm column until 7000 rpms toping out at 23 and 22 degrees.
Seems like everyone has to lowee timing on a 1g to avoid knock, while i've added quite a bit. It does knock, at least it shows knock when i run too lean. So I know the knock sensor works and isnt showing the usual black stuff on it when they go bad.
Am I just getting lucky, or is that just an insane amount of timing?
