ktmguy112
- Jun 21, 2012
anniston,
Alabama
Alright guys i have found a 95 gst close by that i would like to go look at and hopefully pick up if everything checks out. here is the info that i have:
Engine just bored .20 over .new crank, New rod and main bearings , one new rod where is spun the bearing, new gaskets all thru engine. Arp headstuds and cometic head gasket. Turbo back exhaust, front mount intercooler, konig villain wheels with brand new tires. a super clean car clean title in hand . I have all receipts of parts and motor work that was performed .
He says it does need a new tps sensor but thats it. He says it is drivable but around 1/4 throttle it sputters. could this be the tps or possibly a bigger/different problem as well? How would you guys feel about this car if you were going to buy it for yourself? Any info I need to know before I go look at it that I need to check out on the car so there are no surprises? Thanks! hope to be joining the community asap!
also possible he could just be running the wrong plugs these cars are picky about their spark plugs
