compression
- 1,433
- 12
- Dec 9, 2004
vero beach,
Florida
Basically i need an entirely new sunroof assembly.
The first obvious answer would be to just get another one and bolt it in, well the '90s were a little different then the 91-94. if i am not mistaken i believe they have a different hole size completely, although i could be wrong i think i tried to swap once.
The second is the just get a new roof skin, well just browsing around it looks like it would be well over $300 no problem to have one put in. kind of steep for just wanting to fix a hole in my roof
The third option i have come up with is, buying a piece of sheet metal from say Lowe's or something and getting a rectangle a tad larger then the hole, and pressing it against the roof from the inside, put a could spot welds in, then use some body filler ( or whatever ) to make it match.
The car is being prepped now for paint, and is supposed to be painted by next week, obviously i want to fix this A.S.A.P.
Is option 3 a good option? is it really difficult to retain the factory curvature by doing this? i saw a build thread where a guy cut a piece of sheet metal almost the same size and welded it in , basically the same thing, i just thought getting a rectangular piece would be more stable, and being as i have no headliner right now it should be no problem.
http://www.dsmtuners.com/forums/152849583-post12.html
theres his replacement.
