eclipsemf
- 396
- 4
- Jun 10, 2010
Glen,
New Hampshire
Im going to be rebuilding my 6bolt that I just picked up and I just want to make sure I have all the corners covered before I start buying thins for it.
The turbo I will be running is a PTE 3431E, and i will be using stock crank, rods and pistons.
This is what I am planing on getting for it as of now...
ARP main studs
BSE kit
OEM Timing belt, bearings ect
ARP Head studs
Cosmetic HG
ARP Rod kit
Revised 3g lifters
Engine gasket kit
ALC Rod and main bearing set
Crank shaft spacer for BSE
Ferrea or Supertech (not sure what ones) valve guides, seals and locks
264 cams (have already)
Evo 8 (I think) springs and retainers
BC or supertech valves (not sure what ones)
Would like to go to 500Hp or so, not right away but eventually so I want to make sure this will work for this goal, I know a stock 6bolt could get me there but I wouldnt mind having the extra security and reliably.
Please let me know any thoughts what so ever you have with this plan!
Thanks
ARP main studs
BSE kit
ARP Head studs
Cosmetic HG
ARP Rod kit
Revised 3g lifters
Engine gasket kit
Thanks
