Spikefro
- Jan 11, 2010
Union,
Missouri
Alright, just bought the car not too long ago. What i know so far is that cylinders 1 and 4 are not firing. 2 and 3 are. Known good: plugs, wires, transistor, coil, mpi relay, CAS, ecm.
I've been doing a lot of checking on the harness, I've torn it out and ohmmed all of the wires pertaining to the ignition system. A guy before me tried fixing it but it scares me to talk about how he thinks. He liquid taped the transistor connector wires to try to fix it. I've shortened it and resoldered the connector. The yellow wire going in between the transistor and ecm had a distorted terminal which i replaced and resoldered. I'm stuck, in addition the car has low compression and burns oil.
Any suggestions? Thanks
