dsmdeliveryboy
- 2,051
- 5
- Aug 14, 2007
Medford,
Oregon
So one day I was driving and I'm sitting at the stop light and the light is about to turn green so I push my clutch in and put it in gear and the next thing I know the car stalls and I lose ALL pressure. So I replaced my clutch slave and master cylinders, bled them(properly)and still nothing. So I thought maybe my PP collapsed or TOB went bad, so I drop my trans and replace my clutch PP and TOB and pivot ball(the fork is a new jacks racing clutch fork)and I get the car all back together and STILL no pressure. So I replaced my clutch line with a full ss clutch line to ensure I wasn't getting leaks and put in another new OEM slave and wouldn't you know...nothing. So, after doing some research I found out a common problem on a 1G is the clutch pedal assembly goes bad, so I pulled my assembly and got a assembly from shep trans and got it installed and bled the clutch etc and STILL NOTHING. I have NO idea what it could be, it gets SOME pressure and wants to go into gear a little but I am still not getting full pressure and I've tried adjusting the master rod, bench bleeding the master, vacuum bleeding, bleeding how jacks trans says to online and I've just hit a dead end.. I have NO idea what else it could be..
Are you bleeding it right ...Its pump pump pump the clutch pedal have them hold the clutch to the floor , open the bleeder on the slave , let it flow out , tighten then repeat !
, I'm saying its been bled numerous times and no more air is coming out of the system. Sometimes the fluid that does comes out will look a little milky though, I don't know if that has anything to do with anything or if thats just the pressure etc.
