FirstDSMTimer
- 75
- Jun 26, 2011
Baltimore,
Maryland
I know i have post numerous times about my issues and other questions and it seems like im pretty much screwed. So here is my story i bought the car with a six bolt swap with hks 272 cams and a slow boy racing head the car didnt idle right to start due to a bad iac and a ton of boost leaks so the first thing i did was fixed all that bought a new iac and tps because it came with a nt throttle body and a 1g tps and its a 2g. Then i added a few other mods like a e3 16g, Siemens delka 750cc injectors, aeromotive fpr, walbro 255 rewired, aem ugeo, dsmlink v3 lite, aem true boost.
Then i went a did mechanical tuning i set the tps to .63v threw dsmlink and set the throttle stopper so it read anything other then one like the video on youtube Tuning 101. Then i tried to set the fpr while the car was running like in the video tuning 102 and i cant get the fuel pressure below 50psi running with the vac line off idk if it the fpr or the fuel pump anyways so i figured it wouldnt matter to much so i moved on to setting the deadtime and global as someone posted on the site -38 +315. Now i cant drive the car because its not tagged but it will read on the wideband lean that it wont have a reading then out of no where it will surge to 2000 rpms and read like 12.2 on the wideband this is all with out even being on the gas.
now i posted a log but im not sure how to add my air/fuel to dsmlink and it seems like idk what else to add for anyone to help me. I can post another log tomorrow if you guys could help. also what should be normal vac levels because the more i mess with it to idle lower it reads alot lower like below 10.
pretty much i have been working on this car for over a year and it seem like i can't get anything to go right you guys are ###### my LAST HOPE to save this dsm.
