mifiring after a drive
jj2gdsm
166
Aug 26, 2010
riverside, California
I need help my car misfires but only after a drive it and i shut it off come back and misfires. What could cause this i changed the spark plugs gaped then to .28 the wires are about 3 months old, coolant temp sensor is a few months old.:confused:
Boost leak test, vac test.
Test your injectors: turn your car on let it idle and take the injector cap off 1 by 1 and see if you notice a change. If not that injector is most likly bad.
As far at the ECU goes take it out, open it up and search for any signs of corrosion or broken caps.
