nfernotalon
- 1,726
- 4
- Aug 30, 2007
Greeley,
Colorado
Just got back from the dyno kind of disappointed. Only got 341hp at 27psi on e85. I thought it would be over 400 at 27. Seems low to me.
. Cams do sound like a good idea. Could the BEP bolt on housing be choking it that much already?Which compressor wheel?, was the turbo rebuilt prior to installing?
I trapped 132 with an h1c at 30psi with a 54mm wheel in a bolt on FP housing and manifold. This was with 93 and meth injection.
The turbo is obviously working because it is making 27 psi. The fact that it isn't rebuilt has nothing to do with it. It is still moving air. I would bet that it is all in the tune.
Like everyone else said, Timing timing timing! You ought to be at about 12-14 when you hit full boost and ramp it up to 17+ at maxrpm.
If your running close to 45 lbs off that turbo, thoes injectors are cutting it close, you should go bigger like 2100 and get some cams like kelferd 272, very good cams and price friendly. My mhi evo 16g does about 41 lbs and injectors are at like 82-85% (1150FIC) around 7500-8000 rpm and 23 lbs of boost, e85 of course. Do you have any other mods that you havent put on your profile? like a fpr?
I agree that its 95% in the tune. I think my post was really more personal opinion than anything. I just hate seeing people try to throw a 200+ mile junkyard diesal turbo on their car and wonder why its not making 500whp out the gate. To me, that's like taking your car to the track or dyno for the first time without doing the preventative maintenance like plugs, oil and fuel filters, etc. Like others said, tune is where I'd look. Also, when u said you were trapping 80, u meant 1/8th mile, right? I'm just confused ### you said your et was 14 which I assume is 1/4 mile? What did you trap in the 1/4???
I cannot speculate too much as I have never seen the car and don't know a thing about it, but I was at Bandimere yesterday and I will say this.
The car performed very poorly. It never really sounded very good every time I saw it wether driving it through the pits, running it down the track, what have you. And from my vantage point it was not making any power. It just seemed very sluggish and anemic.
I know it hurts to hear that, but we went 13.6 at Bandimere in a full weight 2G with a small 16g in 2004 before we even knew what dsmlink was. That was even without an AFC.
Maybe it would be wise to share some datalogs. And depending on where you dynoed the car, that could be as low as 275hp uncorrected. With that low of numbers, it is no wonder the car was slow.
Where did you have it on the dyno? Who has done or did the tuning? Simple question, but are there any boost leaks? Are either of the wheels of the turbo chewed up?
. You should of went up to me and told me my car was running like crap although I knew that already. I went to trenz it was my only chance to tune it before sunday Mac had a 2 week wait which is where I wanted to go in the first place. Not sure who tuned it, the wheels are perfect nothing chewed up or excessive shaft play.ONe thing that's easy to overlook is base timing.. I had not reset mine after the last headgasket job and adjusting the intake cam back retarded 4* and when i drove the car it felt ok, but extremely sluggish.. I didn't check it due to pain i was in from swapping the gasket being that i'm still suffering from some srious injuries sustained in a motorcycle accident. Anyway.. Just assuming it was "close" i drove the car, kept boost low and watched the knock sensor and although everything seemed ok, the car was being a dog. Just yesterday i checked it and i was running at about 8* ATDC when i should have been at 10* BTDC (where my base timing is set for MY ECU) After setting it up the car gained masssive power everywhere..
The one area that never felt too bad even with retarded timing was cruising, idle and the first few PSI of boost, and that's becayse there's so much timing in those areas that even with 8* taken out there was still plenty there to make good power and get decent economy
might wanna check the base timing according to the DSMlink manual/instructions
also,post that logyou promised us
7"exhaust_tip;153002682 said:37 deg of timing adv?
Did you verify base timing yet?
