A/T (automatic) to M/T (Manual) swap on a Spyder
GRNDSM
Moderator
2,420
189
May 16, 2002
Chelmsford, Massachusetts
So, there are numerous threads on how to do this swap, but I haven't seen this issue addressed:
What do you do about the convertible top neutral/safety switch? I am in the middle of the swap and need to put up the top, but it isn't working. I suspect that that safety switch which prevents you from lowering the top in gear is not working (shifter/tranny are all out at this point).
Where does top controller get this signal?
Even if I manually over ride the top, I will be all set for now, but eventually, I will have to figure this out.
Thank you,
Another related question: at the last minute, I decided to swap in a 5sp engine harness (95 GSX) into my automatic (96 GST) Spyder. I know this isn't necessary, but i wanted to make this a cleaner install.
Some obvious differences:
- manual harness 6.5 lbs
- auto harness 8.5 lbs
- 95 uses "1g style", single MPI relay
- 96 uses "2gb style", two MPI relays
I thought this MPI change happened in 97, but I am obviously wrong. It shouldn't matter, as long as I swap the complete engine harness... Or does it?
I would appreciate if anyone with experience with topic chimes in!
If nothing else, I will report with my finding and we will have some answers :)
I am trying to focus on putting 5sp harness, at the moment.
There are three plugs that connect engine harness to the car (5sp is on top):
The good news is that plug are the same... The bad news is that I can see a LOT of differences in the pins :( So far, I can't find complete pinout of these connectors. Has anyone ever looed them up?
So... it just worked... I am not sure how/where convertible top computer gets its information about neutral gear, but switching to 5sp harness provided all the needed wiring! The top works perfectly! I suspect I would have had to do a bunch of custom wiring, had I kept my automatic harness...
