punk3rz
Supporting Member
- 213
- 95
- Jun 1, 2012
Tennessee
Talon pictures by PuNk3rz - Photobucket
1995 Eagle Talon TSi, AWD, 5spd, 140k
I just bought this car for $500 because it wouldn't run and the owner couldn't figure out why.
After checking the fuses, the main 100amp fuse was blown. I believe this is what was causing it not to start although I could be wrong.
Would that fuse cause it to crank but not start?
I have a few questions, and I tried searing for a vacuum diagram but couldn't find one.
Are all these vacuum lines hooked up correctly? Notice, one is blocked off with a screw. I'm guessing it is an EGR removal or something.
I found this wiring dangling, and I'm wondering where it goes. Is it positive or negative?
Should either of these be hooked up? My buddy told me the vacuum lines were fine but there should be a sensor on that 2 prong one.
What plug is this? Where does it go, and what does it do?
There is also a black and a red wire coming from the harness that were just hanging there as well. What would this be?
Thanks to anyone that can help me.
Normally I wouldn't have this problem, but I bought the car like this and have no idea where they go.
