spyderdrifter
- 5,422
- 854
- Jul 11, 2009
Somewhere in,
Colorado
So, yeah. Only days after getting my baby up and running, it's down yet again. This time it's worse. What's the tell-tale, without a doubt, sure way to know I spun a bearing¿ was heading to pick up a friend, got there, just rev'd the engine once, not hard at all, and when I went into reverse, all I got was a really bad sound like something loose inside the engine. I'm now leaking a little oil from the oil pump, and cyl 3 has an oil leak too. I pulled the valve cover to find nothing unusual, which is how I looked at the pistons, through spark plug wells. I'm lost on this one. Never spun a bearing or had anything loose inside an engine before..
. Let me get this straight..youve "worked on dsms for 9 years" and removed a engine, but yet lack the common sense to troubleshoot a knocking noise? Someone with knowledge like you claim to possess would compression test than drop the oil pan to start. Its common sense. Dont get your panties in a bunch cause you dont know that much about engine internal operation. The fact that you posted about the turbo being a possibility says a lot about how much you know. Dont post things on the internet and cry when you get a response you dont want to hear. You are clearly no expert on engines...maybe do some searching and learn a little before you run your mouth.
I count 9 in punctuation, spelling, and wrong context. Plus there are two in your first post. Please correct yourself before trying to correct others. Don't flame me when you got some work to do on yourself first.
