streetdsmpwr
- 322
- 3
- Oct 13, 2009
Canton,
Michigan
Me and my friend installed FP 1x cams, evo 8 beehives, revised lifters, and all of the timing belt stuff a few months ago on my 99 GSX with 60,000 miles on it. The car ran ok, but it had a little rough of an idle. I assumed it was just because of the cams and needing a new tune. The car sat for a little while after.
A few months later, I installed an FP Exhaust Manifold and decided to re-tune the car for speed density. I had installed the Omni 4 bar MAP sensor and GM IAT a few weeks prior, but I was still just running off the MAF. I re-flashed my ecu with a new tune (I use ECUFlash), but still just ran off the MAF for the time being, as I had to set up my VE table. After the re-tune, my car started running like absolute crap. It is very lean (from 16:1 to 21:1) at idle on start-up and stalls often. Once the car warms up, it will run much better, but it will still occasionally stall.
When I go WOT it will be very rich (10:1 to 9:1) even though I have it tuned for 11:1 AFR. I assume that the richness is due to the knock I am getting from 2000 to 3000 RPM on light acceleration. I did not get the knock before the re-flash. It doesn't happen all of the time, but enough (I assume) for the ECU to switch to the low octane fuel and ignition maps. It seems to be phantom knock, as I don't hear or feel it and it will be large counts like 10-15. When it does knock, the AFR's are around 14:1, so it shouldn't be a lean condition causing the knock.
My fuel trims are now maxed out (positive) even though I had them down to +0.50% before all of this happened.
I have tried a different TPS (off a running car), different front O2 (off a running car), and re-flashed my old tune, but nothing has worked. Please help! Thanks in advance. My profile should be up to date on my setup.
