H@xtGSX
- 1,093
- 11
- Aug 9, 2011
Carlsbad,
New Mexico
I have a 95 GSX that has been my second wife for about a year now. I bought it as a bent valve special from the first owner. He wasn't exactly a stickler for maintenance and treated the car like a Jeep. It was lucky to have the oil changed on time, much less anything else. I bought it, rebuilt the head, did all the needed maintenance, and added a bunch of the crap we all tend to add to our cars... bigger turbo, clutch, etc. I have been driving it daily ever since.
At 126,000 I started to notice the clutch was changing it's engagement position. When I let my foot off the gas and it was engine braking, the clutch would chatter on the flywheel real bad. In an effort to deny reality, I thought maybe I just hadn't adjusted the clutch correctly and fiddled with it in hopes that maybe I was just too stupid to understand the Jack's Transmission clutch adjustment video. It was adjusted correctly, and when it started disengaging near the floor after a hard turn, I decided to push on the harmonic balancer, hoping it wouldn't move... *thunk* ... I can see it move about a 1/16 of an inch. Lovely. I have crankwalk. I can't afford a new motor, I don't want to risk a JDM motor, and I don't really want to do a 6 bolt swap. Rebuild is the only option left, so I start buying parts.
I knew the crank would be trashed along with the bearings, so I bought a new one. $243.99 at Oriley's got me a new crank and a full set of King bearings matched to the crank. I also bought a "conversion gasket kit" that has all the gaskets and seals for the bottom end in it for $45.
Time to get dirty... what better way to show your car you care than by ripping it's guts out?
You have to get it mounted on an engine stand. This requires flipping the motor upside down, so it's mandatory.
Since it's out of the car, clean the motor. I don't want to be doing this again because I was a lazy ass and some little bit of dirt accidently got into one of the bearings before assembly... and while I'm at it, might as well clean the bell housing out too. That Purple Power cleaner works wonders. Yes, that is a 17 year old transmission.
While disassembling the motor, I found a spot where you are supposed to use one of the Mitsubishi special magic tools only the dealer normally has. Screw that. I find that a 2.5" 2 piece exhaust flange, a wrench handle, and a bolt work just as well.
The source of the problem... but look at that main bearing girdle. That's a beefy piece of reinforcement that makes me happy to be keeping my 7 bolt.
Here's what I found with .014" of end play.
...destroyed...
I'm lucky to have done this repair when I did. If I had waited any longer, that block would have been trash too. The crank was already just barely starting to nick the block. The nice thing about doing this though is that all the seals and gaskets are new now... no more leaks, anywhere. Here's the one that is a major source of annoying clutch problems, the rear main. Make sure you take care doing this one right.
It's very important to use assembly lube when replacing something like a crank. You do not want the journal bearings to get scored in the first second it is running when you fire it up, or you will be doing this all over again real soon. As a side note, is it strange that I always laugh when I have a huge tube of lube in my hand?
After carefully dropping in the crank, bolting it down with a good torque wrench, and reversing the whole removal process, I now have a working motor within factory spec. The manual says normal crank end play is .002 to .007. Mine is now .005 with me really pushing on it hard with a pry bar. It's not as tight as a brand new motor is, but it's close enough... Plus, this cost me 1/3 of the next cheapest option for fixing this problem. I am hoping to get at least another 50,000 miles from this bearing set. That would be long enough that I won't mind having to do this again. The 7 bolt motor is built tough enough to take some severe punishment, with the exception being the main thrust bearing, and I am happy to be keeping it... crankwalk or not. It's not nearly as big of a deal as people make it out to be.
...destroyed...
well this kinda sucks! I used the same lube. How long did it take for it to gum up. What made you decided. To check it?
Nevermind what this used to say... I figured it out. For some dumb reason my brain didn't recognize that as the bottom of the block and not the bearing girdle. Time for some coffee...
But seriously, if everything is within spec upon assembly, there is no reason to worry about it.
