huafist
- 1,164
- 13
- Sep 25, 2004
Morristown,
Tennessee
After 4 or 5 years, I'm back in the DSM game finally. Picked up a '95 awd Saturday. It has a few problems, but it won't take much to get it running. That being said:
This is my first 2G of any kind, so bear with me
I'm having an intermittent problem where the car will start for 4 seconds, then die. If I unplug the battery and allow the ECU to reset, it'll fire up and run just fine. It may start 20 times fine, it may start 5 times fine - but eventually, it'll go back to starting & dying. My research leads me to believe it's the CAS, which I'm told is behind the intake cam gear on a 95 - 96. The car ran perfectly fine when it was parked due to clutch issues. It sat for 3 years. I've never heard of a CAS going bad from sitting, but I'm assuming it's possible? Anything else I should try before replacing it? Also, are there any air gap specs or similar for this type of CAS I should be aware of before replacement?
The only other major issue is clutch engagement, and I'm beginning to think the system simply isn't bled properly. I readjusted the rod per the proper procedure, and I was able to put it in gear fine - actually drove it around the block. I parked it, and the next time I started it, it wouldn't go in gear again. I'm gonna get some help when it quits raining and try bleeding it. If that doesn't fix it, I don't quite know what direction to go in next
. I'm having an intermittent problem where the car will start for 4 seconds, then die. If I unplug the battery and allow the ECU to reset, it'll fire up and run just fine. It may start 20 times fine, it may start 5 times fine - but eventually, it'll go back to starting & dying. My research leads me to believe it's the CAS, which I'm told is behind the intake cam gear on a 95 - 96. The car ran perfectly fine when it was parked due to clutch issues. It sat for 3 years. I've never heard of a CAS going bad from sitting, but I'm assuming it's possible? Anything else I should try before replacing it? Also, are there any air gap specs or similar for this type of CAS I should be aware of before replacement?
Just diving right back in
