I've changed my TPS & Air Idle Control sensor and I'm still idling low
bo0st
835
24
Jan 26, 2010
Phoenix, Arizona
I've changed my TPS & Air Idle Control sensor and I'm still idling low my car sometimes sputters down to 200 - 300 rpms and then its like it turns off, but it revs itself back up to 1100 - 1300 like I'm restarting the car.
Man I can't figure out what else to change on the car. I've changed the two sensors, the oil, the intake, ran a bottle of lucas, the spark plug wires & plugs
Sounds like a fuel problem to me. Like its constantly running out then getting a surge. Bad pump, plugged filter, wiring issue, etc. Did you try to "hotwire" the pump so it's getting power to run at all times. Do you have a way to check fuel pressure while driving it.
Just my .02. Hope it's helpful.
Sorry I can't explain on my phone here but do a search for the BISS and ISC subjects. Follows the guides to set your tps + idle switch (inside tps) and test the ISC coils resistance to see if one has opened up or shorted. Clean the throttle body too..
It definitely sounds ISC related, though
I changed the TPS + Idle motors :)
It was the throttle body! A simple cleaning and now I don't have the problem anymore!
Thanks man!!!
