allmine104
- 85
- 3
- Nov 7, 2011
Atlanta,
Georgia
Has anybody had a combination like this? I know the Fp red is close but how will the sl2 compare?it will be with a 3" cover and 7cm turbine housing
thanks
thanks
but i already have a tubular mitsu flanged mani and hard parts to build this turbo td06sl2turbine wheel and 7cm housing...was wantin to know what to expect...oh and no e85 in my area
Im curious what the Tdo6sl2 20g would be like. I have built 2 and im waiting to hear what they will put down hp wise. I build a lot of unique turbos, theres more than 1 way to build a turbo setup to put down the HP you want to see.
My guess is they are slow. There is a reason FP makes a FP HTA Green, and not a TD06SL-20G. The new turbine wheel (TD06H4 or somthing) makes better use of the exhaust energy ( meaning it runs the compressor harder with less drive pressure), and the new HTA compressors takes less power to move the same air.
It's 2012, why do you kids want to keep playing with 1970's turbo technology when you can spend less and use 2000's tech.
Get with the times, put on the big boy pants and step up to a 3052, Green, HX/HY35, S256.
in just tryn to take baby steps on my first build so take it easy on me guy....my girl drops her panties every night don t need a car to do that...wanna drop Z06 vett owners jaws like my delsol used to(rolling burnouts were fun at 90 btw
I like holsets, but MHI turbos are an easy install and are capable if reaching the desired power with the appropriate setup. You try to make it seem easy to go to a holset but it isnt, you never mentioned anything about the maf going haywire from using a 4in intake pipe with a stock maf. Just because FP doesnt build turbos a certain way doesnt mean anything. Everyone has their own way of building turbos. You will see Comp with their monster housings, and Midwest Turbo connection with there rediculously clipped turbine wheels. Theres a post on this forum where a guy made 780 whp on a stock appearing turbine housing.
http://www.dsmtuners.com/forums/newbie-forum/426917-billet-tdo5-turbos-2.html
, I'd like to see an average guy go 130 in the 1/4 on pump with a 20g. Very few people have done it on a RED, and thats got a monster 60mm inducer. sell it.
4" inlet turbo's drop panties.
You like dropped panties, right?
People who run 3" inlet turbo's like to stare at ####.
7cm = ### porn.
You don't like that stuff right?
Mitsu flanged manifolds are like fat girls. Not even fun when your hammered and noone is watching.
Time to step up to the plate and put some man pants on.
And 4" turbo making the maf go crazy? what are you smoking? You have other issues. I've run a 1g maf right on the turbo using a rubber sewer reducer. Worked fine except it over ran at like 11psi, because your actually moving some air. Hell I was running a 2g maf hooked up with some dryer vent for a while with no problems.
Sell it.
7cm = ### porn.
hopn for some good air flow numbers
but you act like its a "cheap upgrade and easy upgrade."
Considering, a $125 HY35 is good to make almost 600whp, I'd say it's a damn cheap upgrade. When anything comparable is at least 500used, and most would be a FP mani anyway.
Seriously, why #### with 1970's tech when you can have 2000's tech for just a little work, and a few hundred dollars.
And don't even bring that maf shit back. If your looking at running a red or a "20g hybrid stage eleventybillion super hta td099sl68 frank level 4000" you are well past a 1g maf and should be on a 2g at least if not sd.
Further more, a mhi housed hybrid should probably be fed off the OFH anyway, making one less thing you need for a big boy turbo.
So to recap, to run a holset all that you need that is extra from a bolt on shit box is:
1. HY35
2. Tnetics cast mani ( most would buy a fp mani, so this really doesn't count)
3. make an O2 housing.
That's it!
Where are you finding the holsets so cheap? I paid 300$ for mine. I have an hy35 on my bmw, but machined it to the hx35 turbine. Im not allowed to bring up the Maf thing, because im right? From your profile pic, looks like you have never done this turbo build.
What? Don't know what I'm talking about? Ha. It certainly didn't affect the 1g maf I had on there at the time. Obviously, it was goofy during bov events, but thats to be expected if its not recirculated.
At the end of the day, all that counts is having a 4" inlet turbo does not cause the maf to go "haywire"
And I never mentioned anything about spool. I stated that it didn't affect the maf. However I didn't notice a spool change when I went to sd.
Why? Hope for power.
1. HY35
That's it!
