agentorange313
Supporting VIP
- 2,028
- 123
- Dec 21, 2008
Westfield,
New Jersey
Can a td06sl2 turbine housing be machined to fit a td06h wheel?
Here are the turbine specs:
TD06h:
Inducer - 67.2mm
Exducer - 58.8mm
TD06SL2:
Inducer - 61mm
Exducer - 54mm
TD05h:
Inducer - 56mm
Exducer - 49.2mm
Most td06sl2 housing look to be an evo3 style housing. This, from my research, is impossible to machine to fit anything larger than a TD05h wheel. So these housing must be cast for a TD06SL2 turbine wheel.
I did notice that the exducer for the TD06H is smaller than the exducer on the td06sl2, I am assuming this is where the problem lies with machining the housing. I might have answered my own question here, but I have never machined a turbine housing, nor do I owe a TD06SL2 turbine wheel to compare.
EDIT:
Ignore the question above, since I had the specs backwards it no longer pertains.
My orginal question still remains, can a TD06SL2 turbine housing be machined to fit a TD06H?
TD06h:
Inducer - 67.2mm
Exducer - 58.8mm
TD06SL2:
Inducer - 61mm
Exducer - 54mm
TD05h:
Inducer - 56mm
Exducer - 49.2mm
EDIT:
. I'll edit to reflect my initial interests.
