2g build
952g63t
401
35
Mar 19, 2012
Summit Point, West Virginia
So after an almost disastrous journey (car carrier dropped a leaf spring on the way back) from MA, I have begun the process of stripping her down.
EDIT: I have to mention something here. I was pulling out of a gas station in PA when the whole carrier dropped on to the axle. I was driving slow, and was about to get back on the interstate. If that had happened while I was on the highway, I don't even know what could have happened. Lesson learned, don't rely on UHAUL to give you safe equipment. :|
EDIT: Found the previous owners DSMTalk "for sale" post.
Didn't get too far today. Was only able to move her to a clean area in my driveway, organize some tools and throw away most of the trash in the car. Did start to dismantle a few things. It started to rain so I had to cover her up and call it a day.
Major issues:
Engine damage from jumped timing
Smashed drivers side window
No intake
Snipped plug wires?
No battery
Mold (I think it rained during the break in or soon after)
Scratched up paint - Door keyed
Right front q-panel needs replaced
Trunk lip is scratched and dented
Missing gauges from pillar
17 years of mucky muck
Wheels were sold or stolen - on temporary wheels
God knows what else...
If anyone has any suggestions on things to double check, things to eliminate etc. please feel free to make suggestions.
Thanks, :thumb:
More pics will be in my profile
@liquidsilver & sypherzero
Haven't tried to turn her over yet. I want to pull the head off first and take a look at the pistons. Plans are to completely strip and rebuild.
Have more pictures here, having trouble getting the seat bolts out. Wondering if there is a way to access them from underneath. I briefly looked and could only see a floor pan where the bolts would be. Also, the shock mount seems to be mounted off camber to the king pin seat. Is that normal? Noticed a crack in the passenger side strut tower. :ohdamn: Opened up the fuel pump access plate, no rust. :hellyeah:
Edit: Got the passenger seat out. The drivers side is proving to be more of a challenge... Found some sort of plug on the passenger side floor, it almost looks like an old school main board connector. Might be from the ABS? Pans are in great shape. So freaking relieved.
More pics;
Removed most of the paneling
Removed the seats
Removed (trashed) the carpet
Cleaned out most of the loose gunk with a Dyson
Removed rear low riser
Removed mouse nest in the windshield cowl
Removed the metal panels that the ABS controller mounts to
Removed at least 20+ pounds of stereo wiring
So far, pretty happy with the condition. Only one small rust spot near the rear windshield washer reservoir. Shouldn't be too difficult to patch up. Any suggestions on what to use?
Hopefully sometime tomorrow I will be removing the sound baffling material, the rest of the sub box that's glued into the spare tire hole, and the rest of the old stereo wiring. Lucky for me, the baffling **** is hardened so i can just break it apart.
Pictures;:boring:
good luck with it! As for the plug on the passengers side, was it under the seat? do you have pics of the plug?
Most likely the plug is for the stock amp, I have one in my 98 gst should be the same.
@tom_and_case
In the picture above, its right underneath the cordless drill
@manny402
Its a MOMO
@1998dsm
I believe you may be correct
@dsm's 4 life
I'm not exactly sure why the plug wires were cut. The previous owner claimed one of the technicians at a shop it was parked at broke into it and stole anything that was easily gotten.
Had work related things to do most of the day so I didn't have much time to spend on the DSM.
Started to remove some of the sound baffling
Removed the exhaust manifold and valve cover
Discovered 2 broken/stripped studs. :tease:One just pulled right out, the other is still sticking out partially, so I might get lucky and just be able to back it out with my pliers. May have to re-tap at least one where the mani bolts to the turbo. Didn't feel any play in the lifters/cams. The lifters/springs look new. The cams are definitely not.
Pictures; Sorry for the bad lighting, it was dark. Comments welcomed :thumb:
Day 4
So much to do, so much grime....
And this dumb sub box is an abomination. 50+ wood screws going into the hatch pan. Sealed in with some sort of black tar ****. :cry:
Must carry on :hellyeah:
Did a lot of detailing on the inside
Finally got most of the sub box out
Removed body kit (needs new mounting hardware)
Removed front wheel well covers
Will prob need to replace the right front qp
More pictures :boring:
Finished cleaning out the wheel well (took 4-ever)
Inspected and finished stage 1 of the porting/polishing of the exhaust mani
I'll prob do at least one final port/polish. Not going to spend a ton of time on it, will eventually get replaced any ways.
Ran out of space for pictures... WTF
You certainly have a project on your hands. It is better this way most of the time though that way you can dedicate time to certain areas and build it to your specs since basically everything needs to be addressed anyway
The fun factor is officially over...
Progress on the engine removal is slow going.
Didn't get a lot done, it rained for most of the day.
I spent some time disassembling the t25 to inspect and re-kit. Didn't finish that because I need some retaining ring pliers. While I was working on it I noticed 2 small cracks in the flap actuator flange and in the exhaust mount flange. Don't think its a deal breaker but it definitely hastens my need to replace it.
Removed more of the sound baffling.
It doesnt look too bad you have a good project on your hands that could have a ton of potential! just curious what did you pay for it??
$1400.00 - Truthfully, I won't know what sort of deal I got until I open up the engine. If its not mangled, I will be happy. :pray:
Alright so, I've been working on a few things here and there. I am currently fighting with an over torqued head stud that is being drilled out. :banghead:
Progress has been slow lately. Should have pictures of the carnage that is my block soon...
Finally got the head off.
So, what did I find? I found 1 piston with damage. It looks like it made contact with one of the valves. I'm not sure why this happened, probably a timing issue. Its almost like something was left in the cylinder like a bolt or something when someone replaced the head, they fixed that and then it piston slapped. It has the perfect indentation of a valve, and then it has some substantial scoring. That or a valve broke, and was replaced with the piston still humped up. The four valves for that piston were different than all the others. That's my best guess.:aha:
The only damage I could see was the piston head, had a small nick near the valve seats. Cylinder walls were not damaged! The head looks like it has maybe 5k miles on it. The piston heads are also very clean for a 95? Maybe it was rebuilt at some point.
Educated opinions welcomed. :hmm:
Things don't look to bad except for the piston head where the valves hit. I would do things right and go ahead and send the head to the machine shop, and i would replace the pistons as well. Idk if there something you can do to that one piston where the valves hit, without replacing.
