josh1095
Banned Member
- 453
- 5
- Aug 27, 2009
st. jacob,
Illinois
just installed pte 1000s, afpr, lc-1,and walbro.
tested everyone and verified it runs correctly after each component went in. the lc-1 went in last. did all the wiring according to this
http://www.dsmtuners.com/forums/art...21002-innovate-lc-1-installation-options.html
the black wire from the o2 says something about push button led to ground? not sure so i wired it into ground. it starts up flashing 7.4 then after 15 secs or so of running it starts jumping from 9 to around 11. i never got up to operating temp.
i also configured the front o2 ecu input in linkv3 and turned on narrowband sim. then i created a log. this time it didnt run lean and seemed to cycle ok but i was running rich according to the wb guage, very rich. is this cause of the temps? its about 25 degrees here today.
another note: i couldnt figure out how to run lmconfig. is it necessary with v3? do i run it through the software disc that came with the lc-1? very confusing. will post log from my laptop in 5 mins
this is the log file
ok, ok, ok, wow my stupidity confounds at times. jesus. im a clinical engineer for gods sake! i missed the whole "look through the lc-1 box and actually read the ####ing instructions" part. i just followed that link i posted. i NEED the led. its basically a programming switch. i think only the lm1 needs to run lmconfig though. just from a bit of reading in the innovative box. oh well, let me know what im still missing. i just worked for 12 hours and was getting a bit foggy at the end. only one major mistake though, not bad.
I just us aux to moniter the a/f on the laptop when i had the lc-1.
