Please Support Rix Racing
20g td06 HP record?
I plan on being on the list as well. Theres not to many people at 600. What hp goal are you shooting for?
Who ya askin?
Much as I can manage on pump and hope to make around 450 on E85.. Link was estimated around 350-360 on 19lbs this summer.
That's what link was estimating for me too. I'm right around 20psi, any more and my iat's go really high and I start to get knock. I think knock from heat is going to be the main limiting factor with the 20g.
I run e85, and my tdo5h 20g was running 30+ psi at 120* ambient temps all summer long. Pump gas. ROFL
Wow, just noticed that. I need to get to a dyno. I suspect there are a few of us that could best that number.
I was thinking the same thing when I looked at that list. You should see what yours puts down when we take mine in to get tuned.
It doesn't state TD05 or TD06. Just 20g Comp wheel. Go for it bro!
I'll let you guys decide if the turbo still qualifies.. I know I can easily lay down 500whp with it.
TD06H4 Turbine (11 Blade FP spec wheel)
3076r Compressor Wheel
It's technically still a 20g, but flows a heck of a lot more than any 20g. Still fit within the parameters????:confused:
Not a 20g. A 20g is any turbo with a mhi 20g compressor wheel. 52.5mm inducer, and 68mm exducer.
I will let you guys know soon what a 20G compressor on an Evo X turbine will do on a 2.3. I plan on upgrading it to a TD06 next year
Not a 20g. But a nasty turbo, nonetheless:thumb:
That's like trying to pass off an FP Green as a 20g:nono:
