BW S300SX 88/75 results
2gGSX
1,956
30
Feb 15, 2004
St. Louis, Missouri
<object width="640" height="426"><param name="movie" value="http://www.youtube.com/v/1x1vi8mavgQ&amp;hl=en_US&amp;fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/1x1vi8mavgQ&amp;hl=en_US&amp;fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="426"></embed></object>
Went to dyno the car yesterday expecting like 550 whp or something. I knew it was fast from the 70-90 and 80-100 times, but I had no idea what kind of numbers to expect. Needless to say, I was pretty blown away when they told me what I ended up making--658 whp and 587 ft-lbs
E85, V3 SD, 36 psi, stock 2g intake manifold, regular 2g head with some cams, and a freshly rebuilt stock trans. Could have ended a lot more disastrously!
Some people were asking me about the misfire and smoke show at the end--the misfire was from the dyno operator hitting the clutch before letting off the gas, and the smoke is a lot of blow by.. need more crankcase ventilation.
cool stuff man, self tuned and just went to the dyno to do some pulls?
I think with some headwork and intake manifold you would pick up a ton of power uptop! Looks to spool fairly quickly too.
Yep! It felt fast on the street, but I didn't really know what to expect. A SMIM would be really nice.. I'm waiting for a JMF Drag to pop up.
what exhaust housing did you use?
1.0 divided T4
That thing sounds pretty nice, I wanted to get the BW 83/75. Congrats on the numbers.
I think that's roughly what the 362 is--take a look at the 88/75 as they updated the turbine wheel aerodynamics.
Thanks guys! (a month or two later)
great numbers ! What is this turbo comparable to in the Garrett or Precision side
The compressor wheel is about the same size as a 4088R, or a "small 40R"
Not bad! With that huge turbine wheel and housing, Im sure there must be a WHOLE lot more in it. Are you going to push it???
Hopefully! Getting a SMIM and hopefully some cam gears to see how I can improve the top end. Car is currently getting an auto swap however, so I'm equally interested in dynoing it on the same setup to see what happens.
Spent a long time swapping to an auto but haven't changed anything else up. I'm going to dyno it again next weekend to see how much power I "lose". I'll probably put in the dual pump hanger and the intake manifold after that.
The local track closed, but there's word of it reopening during the summer. Hopefully that works out, otherwise I'll be trailering it to KC or Chicago to run.
I managed to lose something like 19.5% through the dyno, although it isn't quite that bad. There was a 60* jump in IATs on the dyno because one of my friends who helped put the car back together managed to not tighten down two intercooler hose clamps. Kind of a novice mistake not boost leak testing it before dynoing, but as always there was enough drama beforehand (like finishing an auto swap a few days before).
Even with some boost holes fixed the IATs were still pretty bad, so I'm getting a 24x10.5x5 Garrett core made along with some extra "enhancements" I've always wanted to try out next week sometime, and having the UICP modified for the JMF Drag which isn't installed still. Not sure what direction I'll go with the fuel system. I'm contemplating running a surge tank setup over the Full Blown though. One night while tuning I ran the car down to around 5 gallons of fuel and managed to completely empty the fuel sump on a launch. Wasn't super thrilled about that.
I love the car now--it runs safer and faster than ever now. I was trying to go to the 1/8th mile track yesterday but it got rained out. Next free weekend will be sometime in September.
Pretty much the same plans as before--JMF Drag installed, the biggest off the shelf core Garrett sells, some ducting, and a surge tank with two Walbro 255 (GSL392's). All my old fueling issues are fixed, which actually fixed some of my old tuning issues. Bought one of the DSMLink BCS and it's stupid simple to use as well.
Two concrete things I can say are that--
1. AFRs are rock steady now thanks to not running out of pump, and not cavitating whatever pumps I do have
2. The giant intercooler works. I'm seeing a 10-15* rise in IATs from stall to the top of 3rd, which is an incredible difference. Even in 90 degree ambient temps I never see more than 105 degree IATs. Some people can't even say that when it's 60 degrees out I bet.
There's no easy measure of total performance like a 70-90 with a manual or even an 80-100 because of how the converter works, but it's definitely a lot faster than when I dropped it off. 6700-7700 in 3rd gear before took 3.8 seconds (fat passenger in car, crazy AFRs, crazy IATs, etc), and now it takes 2.8 seconds.
Like I said, I have no idea what that translates to in track times or dyno numbers, I just know it's significantly faster.
Would love to hear more. This is the setup im looking to get.
What fuel pump were you running b4 and injectors and which ducting are you talking about?
I was running a 255 in tank to an 044 inline before. Part of the problem was cavitating the in tank pump. It still supported a lot of power, but it was far from ideal for me.
I got my transmission cooler ducted, and some ducting between my radiator and FMIC. The FMIC itself leaves nearly no space between itself and the bumper cover. Coolant temps while moving now are even better than they were with my old 3.5" intercooler! They do start climbing pretty steadily once I stop moving though, so I'm probably going to need a second radiator fan.
I never ran two fans before because it would take 10-15 minutes of sitting still to push the car to 216-219* coolant temps. With amperage being at a huge premium right now, I'd prefer to avoid adding anything I didn't need. However, now it only takes 5-10 minutes to go to those temps, so it looks unavoidable.
Here's a quick snap of the surge tank I got during test fitment:
Interesting setup. I am hoping to just go with one fuel pump a jayracing to feed some 2150 or 1450 cc FIC injectors. Can't wait to see what your car is dynoing now.:thumb:
