obx green 20g
you will find mixed reviews on that but most people are liking to feed from the OFH (oil feed housing) directly and if need be put in a restrictor. If i remember correctly MHI turbos like higher oil pressure so no need for a restrictor.
Not a mitsu turbo, it's an OBX unit...
I highly recommend returning it if possible, but if you must keep it, ask them specifically what oil pressure/feed point they recommend... I have a big suspicion that the turbo will end up dying.
i understand usually the knock offs are attempted de-engineered builds. How much did you pay for it? I currently have an older style green in perfect condition and am thinking of upgrading. I would always go from the OFH and restrict. Cleaner cooler oil comes from there!
ya.....you do, ever heard of PTE journal bearing turbos going bad from too much oil pressure? Or how about Holset turbos. All of those are JB turbos and absolutely require restriction of the oil feed
Most OBX products are made cheaply and not correctly... Don't get me wrong, they do make some things worth using. However, I would NEVER use their camshafts or turbochargers.
There is zero good stories of OBX turbos working well. Their manifolds are usable, however their camshafts will fail quickly along with the turbo units. There are soooo many engineering aspects of the OBX turbo that is wrong, which will cause the turbine to eat into the housing fairly quick.
Like I said, if possible, return it before you use it... Get as much money back as possible.. There are several MHI 20G's for sell on this forum in the classifieds for a good deal.
Ya i agree, try and get rid of it and pick up something reliable. Ive been the ebay route and it worked and i thought it worked well. Then i swapped to a real MHI turbo and it made a big difference. Definitely more efficient
Curious as I know next to nothing about cams. How can it fail? Is it due to bad metal alloy? How does the turbo fail as well? bad specs in the build?
In the camshafts it's a combination of bad metallurgy and terrible QC causing the cams to literally eat into the the rockers/valve springs.
As far as the turbo's go, there is terrible differences on clearancing and bearing design that causes a very early death. I have literally seen the cheapest eBay units outlast an OBX turbo. The turbo will tear itself apart quite quickly.. It's just a terrible design with not much if any, thought put into shaft materials and clearances of literally every moving piece.
100% wrong. You should never exceed 48psi at the inlet on a MHI turbo.
You don't restrict journal bearing turbos.
Better let Mitsubishi know that so they can remove the restrictor from the OEM head feed line on all 1G 14B turbos as well as Evo VIII and IX 16G's. ;)
it depends if balance shafts have been eliminated.
from a wiseman in another thread
A 4g63 with balance shafts and oil squirters should do fine with a -3 feed line from the filter housing. . . If running no B shafts, a restrictor neccesary to run any journal bearing t-netics/garrett will be fine for a holset. I don't know what restrictor that may be. I just know that garret journal bearing turbos and holset turbos require very similar oil pressure.
I never even touched those points because I knew you'd be in here eventually. I'm sure Justin has had some form of experience with an OBX unit from either a customer or personal experience. I have no doubt his evaluation would lead to the same conclusion as mine.
I stand corrected too :thumb:
glad this was brought up or I would have a dead holset on my hands
It's never fun to have something like that happen... I always recommend triple checking information from a reliable source when it comes to an important thing like this. Most people don't even know what a restrictor is, let alone what their proper flow to the turbo should be.
Actually, I have none to offer. :coy:
Not just a Holset but a turbo of any brand for that matter. You absolutely need to abide by the oiling requirement for any aftermarket turbo you install if you want it to last.
Holset specs are no more than 72psi max, and as long as you're below that pressure and have an ample drain you can have a supply line the size of a firehose. HX35's are fed with a -6AN feed line on Dodge trucks, but the pressure is always within spec and they have a drain that could swallow a small child.
I am one of those folks. I am getting a turbo made.... it was originally a mhi turbo and will be closer in spec to that of a fp green. it will be a journal bearing turbo as well. I currently have a 16g. Will there be a problem although both are MHI turbos? will current restriction be the same?
thank you for your time.
A journal bearing turbo's oiling requirement hinges on it's thrust lubrication system. MHI turbos have a single 1/32" oiling hole in their thrust plate while Garretts have two giant 3/32" oiling holes. The larger the hole in the thrust system, the more parasitic drain there will be on the inlet pressure and available oil flow for the journal bearings.
If you upgrade the thrust system in a MHI turbo to a plate with two larger oiling holes, then you should consider moving the oil feed to the filter housing with a restrictor in order to get the additional oil volume needed to keep the cartridge well-lubricated, still keeping the pressure below the required 48psi max.
ok thank you for the information/help. I will let the shop know about this when the turbo is ready to be installed. Will measure and adjust if needed with the new turbo.
