turboglenn
- 6,375
- 123
- Nov 5, 2007
RIpley,
West Virginia
Hey bud, thought you could use a little challenge being you name off every turbo you see like it was something you learned with your ABC's
Here's some pics...tell me the maker (hardest) what is looks to be (pretty easy)
and explain where the hell i can get a gasket for that exhaust side
this is the turbo i picked up for my bike (gsxr 750) and aside from taking it apart to remove coked oil to free it up the thing actually turned out to be in great shape. (it was given as partialpayment on a DP build and a bunch of other custom work i'm doing on a turbo Civic hatch) IF i use it, i will finish building up the bridge between the gate flapper hole and the turbine outlet and do an external gate on the o2 housing
if ya need hints i'll give them to ya
(i already know maker, what it's supposed to be, but not where to get the gasket aside from making one)
To be honest though although i know what it's a copy of, i don't know which variation it's a copy of some any insight or thoughts based on the wheels is apreciated
Yes, i know there's dmage to the compressor (one fin was chipped, so i "balanced it" by removing the same mass from the other side (ghetto i know but i'm gonna get anew comp wheel and have the assembly blanaced IF i keep it)
_______________________________________
just to add,, i probably have the only air shifted, non stretched bike in this area.. people think the airshift is a BOV already
here's a fwe pics of parts i've built or added
tank for airshift with regulator
here's some preload adjusters i milled out
buttons left to right
dealer mode, pull to turn on "auto shift", and the front one is the timing retard eliminator
pressure gauge now has billet mount
shift minder for the auto shift
the start of the plenum (it's about done but no recent pics)
(i already know maker, what it's supposed to be, but not where to get the gasket aside from making one)To be honest though although i know what it's a copy of, i don't know which variation it's a copy of some any insight or thoughts based on the wheels is apreciated
