Please Support Rix Racing
s366 @35psi 640whp on a mustang dyno!
kp116
620
3
Mar 25, 2009
Janesville, Wisconsin
Took the talon down to ams today to see where it sat at 35psi. The original plan going to ams is because they had a dynojet. Well it seems they got rid of their dynojet for a mustang dyno... I was not expecting to come anywhere close to what it made on a mustang dyno! After the 640whp I bumped it down to wastegate pressure (24psi) and it still made 499whp! The dynojet number might have been 700+whp! Still a lot more room to go! Can't wait for next year!
<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/MOWVb6Y8cFQ?fs=1&amp;hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/MOWVb6Y8cFQ?fs=1&amp;hl=en_US" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/SB-fbIEX2Pw?fs=1&amp;hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/SB-fbIEX2Pw?fs=1&amp;hl=en_US" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
Do you have some specs on this turbo? Is this the extended tip version?
Its just a off the shelf s366 with a .91 divided t4 housing and yes it is the extended tip.
Wow...would love to see the graph as well if you have one! Great numbers.
yea i agree very nice pull. i would definitely like to see the graph on this one
I'd go s366
Bamm.. sitting in my engine bay;) :cool: And can´t wait to push it 30+ PSI on E85 :cool: Saw guy from Iceland /cuzco/ went 9.5 with this baby on 43PSI of boost ;)
Now I have bad times with dial in SD setup in V3 ..No oem Maf with new setup kelford 272 /turbo/SD ..Today will start with idle and crusie..Iam not good tuner /bit scared :coy:
BTW how you feeding that JB turbo..I went 4AN from Head no restrictor and reducer fitting 1/4" NPT to 4AN..no oil in exhaust/hope its okay:pray:
WE NEED GRAPH PLEASE :sosad: :D
What is the flow rating for the S366...?
