Speed Density
streetstyleauto
Feb 22, 2009
Fords, New_Jersey
im getting dsmlink v3
what do i need to run speed density
do i need to get
- SD bundle (MAP, IAT, pigtails and bung)
or
-sd cable
or maybe boTH
ALL FROM ECM TUNING
thanks
if you dont feel like wiring up the sensors yourself, get both. If you think you can tap into 4 wires from the ecu....get just the sensor bundle.
If you get just the bundle you will have to tap 4 wires but will also be able to get the majority of your ve table set up off of your maf. With the cable, it takes your maf out from the get go so you will have to start from scratch with the ve table. It really depends on what you would rather do, tap a few wires and have your ve table mostly set or dont tap any wires and start your ve from scratch.
