BoostedBeaver
Moderator
- 957
- 291
- Aug 15, 2009
Augusta,
Georgia
I was going to reassemble the block when I found this. Right around where the water pump spins you see some wear. I did not notice this before I had It cleaned. Is it ok to continue to run this block?
What would cause this?
The water pump that came off of the block has no play what-so-ever and has no scuffing on the fins to suggest contact. Can anyone explain this and tell me if it is ok to run before I have it bored over?
For some reason I can not get the photos to work so I have provided a link. The first Six photos show the issue listed above. The last photo has a quick drawing to show the part in question. The red is the damage and the blue is the travel pattern of the fins. All help is Greatly appreciated.
Engine 4G63 pictures by robertbaxley03 - Photobucket
