bwhite
- 1,039
- 2
- Mar 5, 2002
Brook Park,
Ohio
Wow Looks nice. I was debating on that manifold. Its a punishment budget right. Is that a inline pump I see bolted up to that sending unit?
Note: This feature currently requires accessing the site using the built-in Safari browser.
He should definitely look into dsmlink whether it be lite or full v3. As for injectors that depends on what he plans on running for fuel (pump 9* octane, e85, etc)
You have an EPROM; with ECMLink you can run as large of an injector as you'd like depending on your type of fuel.My neighbor just bought this car and needs to know what needs to be done before he can turn the boost up a little.
It has HX40 with bolt on housing
-6 fuel lines
255 wally
AFPR
Eprom
rebuild motor non forged .20 over
2g mas
running 9psi
what size injectors?
An AFC with a HX40....something's wrong with this picture. An AFC has a tough time tuning anything larger than 650's, and a HX40 can flow enough air to max out injectors twice that size depending on fuel type.can i get away with just using a SAFC? or do i need rechipped?
Hey Andrew (project gs) wheres my credit for building you that sweet downpipe?
